Discuss Burning smell from socket / plug when using dishwasher in the Electrical Appliances Forum area at ElectriciansForums.net
J
jonwade
I have a 2 year old Hoover dishwasher and a couple of days ago it started causing a burning smell. At first we did not know what was causing the smell but have now worked out it is the dishwasher.
Today I pulled it out and all looks OK. I sniffed the plug and that had the remnants of a burning smell.
Surprise the fuse box did not trip.
We called Hoover and they said £120 to fix it. No idea how they could know what was wrong over the phone ... they then tried to sell their £15 a month cover. We only paid £220 for it, so not going to pay them £120 to look at it or give them £360 over 2 years to "look after" it!
But, what I am wondering is, is it the dishwasher or the actual electrics? Is there a way to find out without putting a different dishwasher in there?
If I called an electrician, would they be able to diagnose the problem by, i.e. determine if a faulty dishwasher or something up with the wiring?
House only 12 years old, on a Tenby fuse box / consumer unit.
Hi Jon, yes is the answer, All electricians will have a minimum call out charge though but should be less than Hoover.
99% it's a fault on the plug/socket. get a sparks in to replace both. it only needs a bit of contact resistance between the plug pins and the socket to cause heat which then exacerbates the fault leading to more resistance,arcing, more heat , and so on. he can PAT test the machine while he's there.
one for dingledong, maybe. he's an essex boy.
Should be less than hoover? Gmes what the hell are you charging haha i'm going sadly wrong if a call out's anywhere near £140
You're like the high-end escort and im just the street corner girl :willy_nilly:
I try to get paid in £50.00 notes due to the fact that i use £20notes to wipe my ar$e with :sifone:
Reply to Burning smell from socket / plug when using dishwasher in the Electrical Appliances Forum area at ElectriciansForums.net
Sorry two questions today. We had the kitchen rewired based on existing units, but with a slightly new layout it puts the dishwasher right over...
Wiring to new dishwasher causes garbage disposal to stop working. I just installed a GE dishwasher and came across a problem with the...
My Whirlpool dishwasher lost power. I checked all of the connections and nothing is loose. Nothing looked corroded. It's a newer model ( a few...
Hi ..right where do i start ..ill do the best i can !! i have an extension lead and in it are plugged a fridge , a separate small freezer ...
I wonder if any one can give me some advice. I live in a fairly new build house it's 11 years old. In our kitchen there is a fused spur switch on...
5K
