Discuss Cable clips as per 18th edition. in the UK Electrical Forum area at ElectriciansForums.net
Friends,
I'm rewiring my brothers house tomorrow. Can someone tell me if the new 18th edition allows me to use the plastic cable clips to secure the cables to joists etc?
Or do I have to replace them with metal ones?
ZippyMo
Trainee Sparks
Is the joist above a plaster board? If so then the plaster board is a fire barrier so plastic clips can be used.
Tin hat on....
No tin hat, plasterboard is rated at 30 minutes. After 30 minutes of fire would collapse be classed as premature?
Just covering my arse mate... :)
What if the fire brigade arrives within 30 mins?
Have a look at this.
How Quickly Does Fire Spread? - https://www.disastercompany.com/quickly-fire-spread/
I'm presuming that this is a worst case scenario, with all the doors open.
I was watching a vid about subject, as well as other matters, hosted by IET. Napit bod tried the argument that cable above plasterboard ceiling needed metal clips. Everyone else in the room surprisingly didn’t agree. I wondered what he would suggest doing during rewire or alterations; get a very small apprentice.
What was his reasoning behind this?
At school I'm sick of retrospectively tidying cables up from past lazy contractors. The amount of times I go and do a job only to see a stack of cables draped across the false ceiling after I lift a tile up. I use metal cable ties, probably overkill because many would argue the metal grid of the ceiling would act as a support, and if that comes down then it's game over, but I'm not sure I could live with myself if somebody lost their life because I tried to scrimp a bit on some clips/ties.
It’s not just the weight of the cables on the grid thats a problem, they shouldn’t be installed on the grid for numerous other reasons.. mainly due to the sharp edges that can cause damage to the cables
I doubt very much that many false ceiling grids are rated as supporting structures for any services let alone to prevent premature collapse.
try telling that to the data donkeys.
I agree, I've just pulled in 20 cat5e cables (supported properly) and my arm was aching, and that would be all weight that likely wasn't included in the design of a false ceiling if it wasn't properly supported. Ceiling grids probably aren't designed against premature collapse, but it's going to cause just as much trouble if/when it collapses as cable would.
That's most of the trouble. Come across one or two bits of T+E on the ceiling, but it's mostly data.
Judge for yourself (7.10mins). Its a bit old now 17th 3 Amendment time;
Fire protection: panel discussion 2 at the ELEX show in Harrogate - https://electrical.------.org/wiring-matters/issues/56/fire-protection-panel-discussion-2-at-the-elex-show-in-harrogate/
Ok, so that was posted 31st March 2015.
It's nice to know that we are still without a reg as to which way to go...
Reply to Cable clips as per 18th edition. in the UK Electrical Forum area at ElectriciansForums.net
Hi There Just a quick one, I'm wondering what's everyone's thoughts on this are. A subby has clipped a cable to a plaster board ceiling using 3m...
Hi Folks , Just looking for a bit of advice as I'm looking to get back on the tools so please bare with me if this is a bit long winded. I'm a...
I'm facing a dilemma and any advice would be hugly appreciated. I'm transitioning from the military into becoming an electrician. I've completed...
An old and now deceased friend's place has some rewirable fuses with asbestos flash pads. They are long overdue for replacement and now that seems...
In a property with two consumer units one for the ring main etc., and the other for the 1970s storage heaters (storage heater CU looks like it’s...
