Discuss Chimney height regulations/removal in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
if it's not required then as far as i know, there's no reg. says you can't demolish or reduce the height. seen loads that have become unsafe removed.
all you need to worry about is that the chimney has enough height to flue the exhaust gas out.
Building Regs Approved Document J Diagram 34 should lead you to the answer, although you might have to refer to manufacturers instructions or a BS depending on the type of flue outlet.
Currently only used for a gas fire - presumably the height of it can be reduced very low?
It is a large chimney on a bungalow.
personally, if it's used as a gas flu we don't touch it, as there could be severe liability issues if you'd somehow ended up blocking the flu while doing the work, which would be fairly easy to do by mistake in unlined chimneys.
I don't know the exact regs on it, but our gas safe engineer had much sucking of teeth and looked very concerned when we discussed it, and thought we'd probably need to issue a gas safety cert to be on the safe side, so it's simpler just to say no IMO.
Any other chimney though, and we'll cap it at ridge height no problem - getting it below the roofline entirely is a bit more of an undertaking if it's through the ridge. AFAIK it's not a notifiable work as long as there's no structural element to it and it's not used, but I could be wrong (hopefully not).
I'm gassafe registered so could lower the flue and check the safe operation of the gas fire and flue after the work was done. You could get a gassafe guy to take a look might cost about £45 for that and probably £65 to service the fire(and check the flue) after the work has been done.
If you take the chimney down below roof level you will have to notify building control as you will be altering the roof structure, and be aware if your in a conservation area you can`t do anything to the chimney at all, a local person in my area of wales removed his chimney because it was unstable and they made him re-instate it with the same stone.
Reply to Chimney height regulations/removal in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Good afternoon, Sorry for the long post but can find answers to my questions anywhere. I’m want to replace my old cooker hood for a new one...
Evening all.. I have just been core drilling a 105mm hole for an extractor fan in a bathroom wall. I had a good look around on my pre works visit...
I had a PV system installed by a local reputable manufacturer last autumn; since then, I've received conflicting advice regarding the consumer...
Have a contractor trying to run a new electric line to a 'picture light' over the fireplace mantle. As you can see in the photos, the entire...
Hi all. Customer asking me to fix 3 phase consumer unit on a new shop . Its brand new installation . He want to use every part of shops and he...
