Hi guys, I've been given the task of installing a 32A commando socket w/ isolator, which will have a 27A oven plugged into it. It will be on a C32 30mA RCBO. The cable from the oven is 4mm which will have the 32a commando plug fitted to it.
My question is, should I wire the 32A commando socket in 4mm or 6mm? The cable run isn't very long so voltage drop won't be an issue.
