Discuss Cut through an alarm cable in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
G
GraniteGuy
Don't know where it goes to (magnetic contact we think) but the Customer is happy to have that cable disabled. There are four wires - do I simply wrap all four together so the rest of the alarm can be switched on ?
You will need to identify what cores are used for the alarm and tamper circuits then join each of the cores together for the alarm and tamper circuits joining all four together will cause a fault which will stop the alarm arming. You could get an alarm JB and reconnect it would save time identifying what the cable does
If the magnetic contact is on the exit door the system may not set if it is programmed for final exit set and the door contact has been removed from the system
join the cables, colour for colour, if there is insufficient slack, the use 2 alarm JBs. If the alarm won't work, you'll be blamed.
Thanks. I tried a few different combination's and eventually figured out to wrap the blue and yellow together and the red and black together. Jobs a good un'
Reply to Cut through an alarm cable in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Can someone please guide me on this? I have virtually no experience of home alarm systems. The client has an alarm which had been fitted to her...
Hello, I have 50 ft of corrugated pipe buried between my house and a pool shed. I placed it where I knew future landscaping would make it very...
Hi all, I currently have a Pyronix Enforcer V10 Wireless alarm system. I have some shock/contacts on windows, doors, PIRs, and an external siren...
I'm starting a new project on Monday, new dental practice conversion from a shop. Nothing new here, customer doesn't know what electrical heating...
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
