Discuss Dimmer Query in the UK Electrical Forum area at ElectriciansForums.net
B
BMelectrics
Hey All,
I installed two sets of 6 lights, each set controlled by a dimmer.
When i bypassed the dimmers, i got 240v at the end of line lights.
when the dimmers are connected, i got 208v at the end of line lights.
The dimmer switches were on full, i dont know where im losing the 32v?????
Is the a problem with the dimmer switches??
The output waveform of the dimmer is not a sine wave, it has a very steep rising edge. The rising edge often spikes very high momentarily and immediately drops again steeply followed by a more rounded trailing edge. Your tester isn't designed to measure this type of waveform accurately, it's designed to measure nice even sine waves so take the voltage readings with a pinch of salt. Any current readings are also likely to be somewhat inaccurate especially if your ammeter isn't measuring true RMS.
It's also worth noting I've seen cheap electrical testers that show a full dimmer output as being 20 or 30ish volts. This can be especially confusing and dangerous when you're trying to prove isolation from a light fitting. It's not uncommon for digital testers with high input resistances to show a nominal small voltage on a circuit that is fully isolated under normal conditions. The poor interpretation of the dimmer output by the tester might be mistaken for the circuit being in an isolated condition.
there's always a curveball thrown!!
Reply to Dimmer Query in the UK Electrical Forum area at ElectriciansForums.net
Hi there, I am looking at specifying a Triac dimmer switch after a PIR and manual override to control several lights, i dont see an issue why...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
I have carried out home wiring for 60 years as a competent person, for the last 20 years, I employ a local electrician to check my work and sign...
I am looking at installation of an architectural dimmer, that is will supply 6 channels, with 20A circuits each (2400W ea). Our hall has can light...
Please can anyone recommend a smart dimmer module for use with Aurora LED GU10s that remembers the dim setting on loss of power so that the lights...
