Please can anyone recommend a smart dimmer module for use with Aurora LED GU10s that remembers the dim setting on loss of power so that the lights don't come back on full brightness (or, even worse, remain off) when power is restored? Ideally Wi-Fi controlled. There isn't sufficient space in the back box for a module and there are only neutral, switched live and earth in the ceiling void.
TIA
TIA
