- Reaction score
- 14
Hello All,
I've been asked to supply distances between draw-in chambers for a large job.
The SWA will be in 4 -8 inch PVC drain pipe under the ground (about 5-6 feet down in places but never above 3 feet). Due to the cable varing in size from 35mm to 150mm I'm thinking a distance of 40-50m between chambers. Pipe will not be crowded, if anything it looks like each cable will have its own pipe!!!
Some others here are saying 70m will be fine.
What distance would you gents recommend?
All the SWA I've laid has always been in a trench so this is a first for me.
