Discuss Do I need a 415v coil contactor? in the Lighting Forum area at ElectriciansForums.net
Hi guys, first post on here so hope it doesn’t sound too dull. I’ve recently qualified but my background is domestic...recently started with a company working in commercial so haven’t had much experience in working with contactors. But basically I’ve got 3 rows of lights that need to be separated with individual switches as they are all on together at the moment..what I can’t get my head Around is if I use a 3phase contactor with my switch wires coming in to energise the coil won’t that effectively turn the contactor on so all 3 of my loads become live? Do I need to have separate coils like 3phase coil or separate contactors?
A contactor is an electrically controlled switch, you will need one for each load you want to control.
Power >> switch >> contactor coil
Power >> contactor line terminal || contactor load terminal >> lights
If you currently have 3 phase going to the 3 lines of lights and you want to turn on each line individually then you will end up using 1 phase per line of lights. Single phase. As above, each switch will switch on its own contactor, so the contactor will be single phase.
Most Manufacturers do a single module contactor rated at 20A however they are only 230V coils so you will need a Neutral across A2 and a feed from each switch to A1 let me know if want a drawing..
Reply to Do I need a 415v coil contactor? in the Lighting Forum area at ElectriciansForums.net
I have a sawbench motor that needs an on/emergency off switch fitted, have the hylec on/off switch and a contractor 240V coil with NC contacts...
Hello all, I know this is very simple but I would like some advice please. I am installing a new circuit to feed 5 external floodlights. It is...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi. Can anyone offer a bit of advice please. I've got a customer who wants needs an upgrade to their consumer units. It is a bungalow that has a 3...
7K
