H
hoover
well not quite a fire but charring. It was a couple of lights i changed a couple of years ago for a mate. From ceiling roses to these decorative lights with metal base, 100w haleogen lamp and glass cover. Anyway he rings me and tells me that everytime he trys to turn the lights on the trip goes. so i went to investigate and found when i took the first light down a lot of charing as if there had been a small fire in the wooden ground above the plasterboard ceiling. To say i was shocked would be an understatment. Now the second light was fine so i think i can rule out heat emitting from the fitting as the cause. All connections were sound- the 15a plasic connectors had'nt even melted but the cable feeding the light had melted slighty so causing the trip to blow. The house has only been wired not 10 years ago however i think i may have come across in the past a borrowed neutral somewhere between the 2 lighting circuits. Dont think this to be the cause but its got me baffeled otherwise. Any thoughts people?
