Discuss Don't suppose these exist? in the UK Electrical Forum area at ElectriciansForums.net
Zdb
Need to install a load of outdoor sockets to be used for Air-Con equipment (vac pumps etc) local to some condensers.
Anyway I was just wondering if there is such a thing as an IP rated 3 position rotary switch?
The idea is that the normal rotary isolator could power the condenser in position 1, Isolate in position 0, and in position 2 just power an IP rated RCD socket.
I'm probably just dreaming but it would save a lot of time and hassle on a job I've got coming up. Less time I spend on this site the better!
If it is CEF tell them you got a price elsewhere for much less and you dont want to drive unless you have to so will they match it. 9 times out of 10 they will as its mickey mouse pricing in CEF
These look good
Haven't managed to find a lockable version yet. Like a normal rotary isolator
Reply to Don't suppose these exist? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I'm planning on adding some lighting to an old stone shed, there's currently a 2.5mm² SWA supply to the shed only supplying one IP rated...
Hi, This post is about my concerns with medical IT socket outlets and want to alert you all if you are fitting them in a hospital. The current...
Just had three split Air Con units installed at my home, the ones with an indoor and outdoor unit. I (perhaps naively) trusted the installers...
Hi all, Just a quick one regarding the need for RCD protection for socket outlets rated up to and including 32A. I have been tasked to install...
I had Scottish Power moving a supply this morning from one building to another so an extension could be built. I had everything ready for them...
