Discuss Drill Breakdown in the UK Electrical Forum area at ElectriciansForums.net
Hello friends.
I use a Black & Decker 710W Drill.
I took a break to get some rest while I was working.
The drill was not working when I wanted to work again.
When I press the button, I read 220v value with the measuring device at the switch output.
The brushes seem to be touching the commutator, but I don't quite understand where the problem is coming from.
How should I proceed to diagnose the problem?
How can I measure motor windings? I have a multimeter
It is a series-wound universal motor. There should be continuity from the switch through one field coil to one brush, from that brush through the armature to the second brush, then from that brush through the other field coil back to the switch.
The resistance reading between the brushes includes the contact resistance between brushes and commutator which is variable and non-linear. If you move the commutator it will might dance around; this is normal. The resistance through each field coil should be low and stable.
Thank you for your reply, but I do not fully understand it because my English is not sufficient. My request from you, can you show me what and how to measure by drawing a picture? Or is there a video of that?
I'm not sure how to do it. Can you explain a little more explanatory from the picture? At what level should I measure, how many values should I read?
Why don't you put it in the bin and buy a new one, they are not expensive and are considered a throw away item for that type of small unit.
Reply to Drill Breakdown in the UK Electrical Forum area at ElectriciansForums.net
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
Friend of mines dryer machine has stopped working, 2 days out of warranty. I am trying to help theme out as money is tight for them however, I'm...
Hey, I want to use an old xbox 360 PSU- 12V 175W output- for my 12V sup pump (pump/air compressor). When I connected the PSU to the pump...
I want to check the insulation of the 3-phase 400VAC asynchronous squirrel cage motor. Motor's stator windings are connected in delta. I've read...
Hi everyone, I need some help with an electrical issue I'm experiencing. I recently created a new circuit for an electric oven at my friend's...
