- Mar 11, 2010
- 688
- 77
- 1,203
- What type of forum member are you?
- Electrical Engineer (Qualified)
Hi all,
Just fitted a car charger , I need to put an earth spike in but having trouble siting it, the main consumer unit is on the garage wall , directly behind it is earth as the garage is set into the hill if you know what I mean so if I drill through the wall I will hit the mud, is it ok to then hammer the rods in so the rod will be out in horizontal and the rod box fitted on the wall underneath the consumer unit?.
Cheers
Grand
Cheers
Grand
