Discuss Fitting an 'APT Timer' to a dual Immersion Heater in the DIY Electrical Advice area at ElectriciansForums.net
Hi there, I'm looking for some advice regarding the above, I have a very basic type 'on/off sink/bath' switch on my copper cylinder immersion heater, I want to ad a very basic timer as mentioned above i.e. the mechanical dial types that have push/pull pins etc. the instructions that come with the timer I have attached..........my question is there are two 'live wires' (brown & Black) going to the elements in the immersion, from diagram 2 on the attached can both the 'live wires' be wired/connected into the same terminal in the timer....?
If you have switch that says sink/bath you probably have a dual element immersion heater. Which element do you want timed?
yes I have one that says sink bath, do I just select which one I want to put on timer and wire it/connect it to the terminal, if so what do I do with the other wire......?
Your timer requires a permanent mains feed, so the only place that you can put it is in the mains feed to the bath/sink switch.
Then the timer will switch on and off the immersion you have selected with the bath/sink switch.
Is that what you want?
As above, it has to go before the bath/sink switch. As you are in Ireland you should consider getting a REC to do this.
Bear in mind that this cannot go in the hot press - if your installation is a number of years old then that is likely where the current immersion switch is. Also an immersion heater needs to be RCD protected.
If in any doubt consult a REC.
Reply to Fitting an 'APT Timer' to a dual Immersion Heater in the DIY Electrical Advice area at ElectriciansForums.net
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
Until last week I had a dual tariff electricity supply with a cheaper overnight tariff. This was good for the storage heating, but now the storage...
Hi, I'm about to switch to an energy tariff whereby i think it would be better/cheaper to heat my water via my immersion heater and not my gas...
Hey there! I am fitting four lights in my kitchen and have come across two issues (pictures attached - this is really the best quality I could do...
