Discuss 'Flatmate' door entry system in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
hi guys.
i recently bought a flat that is ex council, 6 flats in the block and has a very old looking door entry system called 'flatmate' thats all that is on the internal box inside, it has a open, talk, and a on/off button for privacy,
It is a 6 wire system. green, blue, orange, orange white, blue white, green white.
i was wondering if there is a replacement.
ben kelly
hi guys.
ben kelly
Hi, did you have any luck with this?? I've got the exact same and it's not working.
Heres a pic, I was hoping some cables would be loose.
Have you got a multimeter?
First thing - is there any power to the board. Check the 556 IC between pin 7 (gnd) and pin 14 (should be between 4.5V and 16V). May need to push a button to see if power appears there ??
Presumably there is a power supply module somewhere in the building to run this? Is it switched on and giving an output?
Reply to 'Flatmate' door entry system in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
I have removed and looked at the old entry phone. It has 6 wires. Blue plus blue and white. Green plus green and white. Orange plus orange and...
Hi. Looking for help. My FiL has moved into a block of flats using the Bell 801 door release intercom for opening the main communal door to the...
Hello everyone. Budding DIY enthusiast fascinated with how things work - and, to a lesser degree, fixing things that are not working. I suppose my...
Hi guys, first time posting, please bare with me! I have an old test chart as shown in the pics that i would like to get running. Everything...
