- Reaction score
- 5,845
Like the gas boiler that insists on a fuse in both live and neutral?Follow mf data lad , keep it simple..
Discuss Fuse too big on fridge in the UK Electrical Forum area at ElectriciansForums.net
There is little between 2A and 3A, as opposed to a draw of 0.32 A and 13A. The difference is massive.I contend that the 13A fuse is not 'wrong' as was the premise of the thread, any more than the 3A fuse in my heating system FCU is 'wrong' because a 2A would work.
Mmmm, can't think of many inductive domestic loads of around 1kW. Most - heaters, hair drier, tumble drier, kettle, etc., are more like 2kW, and would pop a 3A fairly quickly.Then the people-who-don't-bother-to-change-the-fuse will use the 3A-equipped plugs on 1kW loads and cook the plugs and sockets.
If they are heavy use...no. My dryer is on an FCU. The connection behind the dryer is on Wagos, which gives a better contact than screwed terminals. Screwed can also work loose over time. The Wagos also give a quick disconnect in case of appliance replacement. The appliance is on its own radial with its own RCBO.Different issue completely. That's a bad connection. I've also seen damage at the connections of 13A sockets due to loose connections.
Are you saying washers and dryers shouldn't be connected via 13A plugs and sockets ???
People I know with a large family. The dryer was hardly ever off. I looked at the plug and socket seeing brown marks. I fitted an FCU then to a box with Wagos inside with dryer cable running into the box - for easy disconnect, as I could see frequent appliance changes. That was five years ago. No brown marks to be seen.There is no issue with a dryer being plugged into a 13A socket.
Yes, if there is a loose connection, or a cheap brand socket is used then there could be problems. But you can say that about anything. There could be a loose connection at the screw terminals of the RCBO.
Lots on Efixx Youtube site. The claim is they, Wago, etc, do not work loose, also give a better connection as it grips the conductor all around, not just top and bottom.I might explore this quite wide-ranging assertion in another thread when I have more time.
13A FCUs aren't much better than a plug these days. This example I replaced this week with a 20A DP switch after a maintenance company had replaced it three times this year with a FCU, supplies a ceiling heater and this wasn't looView attachment 86165se connections.
What maker?13A FCUs aren't much better than a plug these days. This example I replaced this week with a 20A DP switch after a maintenance company had replaced it three times this year with a FCU, supplies a ceiling heater and this wasn't poor connections. It is welded in the on position. View attachment 86165
How about a DP mcb in a box as an isolator.13A FCUs aren't much better than a plug these days. This example I replaced this week with a 20A DP switch after a maintenance company had replaced it three times this year with a FCU, supplies a ceiling heater and this wasn't poor connections. It is welded in the on position. View attachment 86165
I came across an oven and induction hob with flash looking chrome isolators on the worktop. The tenant was using the isolators as the on-off switchs, sometimes switching when large currents are being drawn. The contacts were burning out. It was a flat with luckily both appliances having their own mcb's at the CU. I removed the isolators, connecting the cables using Wagos then fitted chrome blanking plates over. Danger gone.13A FCUs aren't much better than a plug these days. This example I replaced this week with a 20A DP switch after a maintenance company had replaced it three times this year with a FCU, supplies a ceiling heater and this wasn't poor connections. It is welded in the on position. View attachment 86165
The CU was well and clearly labelled. Customer was told if a problem go to the CU which was in the hall at face level. All easy to get to. But danger gone.Am I missing something here? You removed the local isolation for a cooking appliance? So if something happens and they need to isolate in an emergency, they have to go back to the consumer unit and switch the MCB off. And find the right MCB and hopefully not knock the lights off by mistake.
I'd have been educating the customer on using it as an isolator, not an operational switch.
Reply to Fuse too big on fridge in the UK Electrical Forum area at ElectriciansForums.net
