I'll cut to the chase - bought a 1500 watt pure sine wave inverter, which has a small screw and a nut coming out of the chassis labeled "ground", and they provide an associated 12 inch wire, ring at one end, that I can of course attach and tighten down to this exterior screw. The other end of the 12 inch wire is an alligator clip, implying I clam on something to ground it. What the heck can I ground it to? It's going to be stationary, on a shelf in my garage - next to two 100aH batteries. There are two standard electrical outlets near by, which made me wonder - why doesn't someone make an adapter that I can just plug into an electrical outlet that provides me a way to connect to the ground portion (bottom prong)? Anyway - any help appreciated, I am a novice as I'm sure you can tell. I did buy the right inverter and batteries though, it's just a system to run my chest freezer for an hour in the middle of a blackout.
