Discuss GU10 lamp holder leads? in the Electrical Tools and Products area at ElectriciansForums.net
I get all my lamp holders off ebay
my local wholesalers can’t get anywhere near the prices on eBay , last time I was in a pinch I paid about £4 just for one at my wholesalers
on eBay you can get 10 for about 7 quid
all much of a muchness. low current, anything will do, apart from the girlfriends knickers.
You can get a jcc fire guard gu10 fitting with bezel for £3.99, by the time you alter the lamp holder, add a wago box and wagos, and still left with an old fitting and a bit of a lashup, is it not worth just doing it properly and swapping the whole thing
likewise you can use integrated JCC V50's where the drivers will accept 2 T/E, saves the wagos and boxes. c. £15 apiece.
Reply to GU10 lamp holder leads? in the Electrical Tools and Products area at ElectriciansForums.net
Can I use multiple GU10 led lamps with their own PIR sensors in the same room? I have a row of existing lamps 600mm apart in a straight line & I...
I have been asked to rewire an antique metal standard lamp. It has been rewired previously, but not earthed..! One of the screws on the base has a...
5K
Hello All Living room will have 12 GU10s. Can anyone recommend any dimmable bulbs that won't flicker and be around 400 lumens each? I've got 4 in...
Hi all, I guess most of you have seen some moving spirals in some fluorescent lamps. Not sure if there's a better description for that, but with...
Hi I wanted some advice regarding which downlights company is better from ancell or forum? I have builders doing works in my house but I wanted...
