Discuss Help with room thermostat in the DIY Electrical Advice area at ElectriciansForums.net
G
Gib
Hi not sure if this can be posted here but it wont let me post to the diy'er forum!!
I have a ferroli domicondens f boiler which is volt free and i have a towerstat rf wireless thermostat to wire to it but am a little confused as how to wire it in!I have found the loop i need to wire to in the boiler and i know i need to connect to the mains but there is a 5th connection i dont know? Any help would be gladly recieved thankyou..
tried that , WP, but access forbidden.
OK,the link worked when I first posted it....google 'towerstat RF thermostat' and a site at WWW.tfc will come up....there is a link to a PDF manual with a diagram of VF connections on page 10
Thankyou so the Live from load and the Switched live output go to the boiler loop and the neutral supply and the live supply come from the mains and the other connection is left unconnected yes?
Almost certainly, yes.
However, if you're not confident with electrics (which judging by post 7, you're clearly not), it might be better to get an electrician in.
Reply to Help with room thermostat in the DIY Electrical Advice area at ElectriciansForums.net
Hi there, We have recently replaced our central heating programmer with a Honeywell ST9400C. We now want to replace our old wireless room...
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
Hello, I have a regular boiler doing room heating only, with a Drayton programmer (for time) + a Drayton dial stat (for temp). I've bought a...
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
