Discuss Hoover tripping the electrics in the DIY Electrical Advice area at ElectriciansForums.net
steveohim
Our Hoover has started tripping the electrics, I've tried it on a different socket and changed the fuse etc but I'd doesn't make a difference, it was fine the last time I used it.
Does anyone have any ideas?
Impossible to answer, could be any number of reasons. Try another hoover,if nothing trips then it's your hoover at fault.
It's definitely the Hoover I've tried it at 2 different sockets
Buy another hoover then....actually,no...buy a Miele, vastly superior. Just don't buy one of those dreadful Dyson thingies, the biggest con in history. How that fella's managed to persuade millions of people to part with billions of pounds for a pile of junk is genius.
Hum.... I've seen this before and the fault was in the lighting circuit (single up front RCD)
What is tripping?
buy a henry.
The main switchboard is tripping
If it is a single RCD covering a number of circuits then as already stated a fault on another circuit may cause tripping when a load is applied to any other circuit. As I already stated try another hoover,borrow a neighbours or whatever and see if you get the same result. Given that most of todays 'hoovers' are class 11 with no earth then a fault on the appliance itself would not normally trip an RCD.
It's a dead Hoover, it's deceased no longer functional it's finished dead knackered get a new one
dead my arse. send it here. i'll have it stripped and rebuilt in under an hour.
I've relocated this to the DIY forum. Please stay on topic everyone, thanks.
It turns out it not the Hoover, the kettle also trips the electric out, it seems anything with a 13amp fuse does it
We have one coming round tomorrow but I can't see how it could just happen out the blue
Reply to Hoover tripping the electrics in the DIY Electrical Advice area at ElectriciansForums.net
Hi I am asking for help as a novice and 1st time user of this forum. Recently started to experience tripping of MCB & sometimes with the RCD at...
Hi, I seem to have an RCD that keeps cutting the power at random times without actually tripping, if I reset it, the power comes on and will stay...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
I have just replaced my old double oven which was about 10 years old with a new model as whenever I used the top oven it tripped the electrics...
