Discuss House 3 phase really needed? in the DIY Electrical Advice area at ElectriciansForums.net
S
sam423
Hi guys
My 3 phase mains supply cable needs rplacing as its burnt out and very old.
My question is do i really need to use 4 cables again as nothing in the house is 3 phase and the load is not split?
There are 4 cables going into the top of the ' rcd' switch but only 2 coming out of the bottom to supply my lights and socket switches.
Any help appreciated
Hi guys
1. Is this installation in Spain, and if so, how many amps per phase? 2. What do the other two phases do, as they are connected to load terminals of main switch?
HiYes it's in SpainHow can I tell how many amps there are per phase? I know there's 110v eachThe 4 cables go into the top of the main switch then out of the bottom into top of ,rcd' switch but then only 2 cables come out of the bottom of the 'rcd'.
Ok but where do other 2 go then?? Also I mean how many KW per phase?
There are no other cables. Only 2 come out of the bottom of the 'rcd'.
Reply to House 3 phase really needed? in the DIY Electrical Advice area at ElectriciansForums.net
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
Hello All So I'm not long out of my college days and unfortunately I didn't have a lot of exposure to three phase and commercial wiring systems...
Hi, leading on from my question the other day about running the 3 phase compressor off my 8.5kW generator I have since got my hands on a 240v to 3...
Hi Guys, We have a CNC router which uses single phase for the spindle, stepper motors and control box. This is all wired in and working...
