Discuss How do I install an outlet ( metal junction box with a gfci ) under sink for dishwasher safely? in the Electrical Appliances Forum area at ElectriciansForums.net
craigwolf
I was having a dishwasher delivered from Best Buy but they wouldn't install unless I had a dedicated outlet for the new d/w plug. I looked up code and its supposed to be under sink. I went to Home Depot & Lowes and they told me I can do this myself. So each helper I talked to had a different plan. The one I decided upon was the metal junction box with gfci under the sink.
What they had there, the gfci didnt fit any metal handy boxes. So I had to pull tabs off of the box and the receptacle so it would fit in. I got the larger one to allow more space. I needed to get screws for the outside of the box and lots of things, some of them protruding in some manner. (screw from faceplate to hold the gfci in sticks out about 1/2 inch and I put a bolt around it.)
So, I:
1) Drilled the hole from d/w opening to under the sink. ( It was 1" hole that is recommended online, but the new d/w plug doesnt fit that, so it had to be 1 .5")
2) Electric off
3) Ran cord inside, put into the box hole. Attached the black to gold, white to silver, and the ground. The ground wire was hanging off the back exposed.
4) Pushed it together and the ground wire was touching the metal back of the junction box.
I then started to wonder if Im making some kind of mistake and want to get help on it. I saw online it talks about grounding the junction box. Im not sure what to do with the ground wire that would touch the back of the metal box, and possibly a metal screw touching the exposed ground wire.
How does the wiring and installation look and where do I go from here?
Its on a dedicated 20 breaker.
So, I:
2) Electric off
You are required to ground the box since it’s metal. Inside the box there is a hole that is threaded. Go to Home Depot or Lowe’s and buy you a green ground screw to install in your box. You need 1 ground to the box and outlet. Make sure you wire your cable on the line side of the GFCI which is labeled on the back
Reply to How do I install an outlet ( metal junction box with a gfci ) under sink for dishwasher safely? in the Electrical Appliances Forum area at ElectriciansForums.net
Wiring to new dishwasher causes garbage disposal to stop working. I just installed a GE dishwasher and came across a problem with the...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
I collect old Electrical Fittings and I recently acquired this vintage Junction Box (photos attached). I've been trying to figure out how it would...
Hello everyone, Following on from my previous post where I received advice on taking a spur off a 40a feed (thank you). I performed the work...
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
