Discuss How to disconnect a Lucas Rists 1988 connector? in the Auto Electrician Forum area at ElectriciansForums.net
Looking for advice. I've spent the last three months diagnosing an electrical issue on an SZ series 1988 Rolls Royce Silver Spur and have located the suspect wire on the starter circuit. I've got two questions:
1. Can anyone advise me on how to get a wire disconnected from an old Rists connector (looks like a 3mm female spade - see photo). There only seems to be one side I can get any kind of spiked tool into, but there isn't any prong in there from what I can tell. Is there some other wisdom I'm missing here that anyone can suggest?
2. I need to replace the wire which is on the starter circuit between the gearchange actuator and the starter relay. It looks like a 14 strand 0.5mm wire (including the insulation). How can I figure out what gauge I need to replace it with? The only fuses on the same circuit are 20 amp and 10 amp.
Am so close to solving this after endless tests, but am getting stumped on this last hurdle. Any advice would be warmly welcomed.
if it's cable damage, can you cut it leaving some in the connector, and joint in some new cable to replace the damaged section?
There are some videos out there that I watched a while back, but can't immediate;y find at the moment.
However, plenty kits designed for dismantling connectors are available, and maybe that might help:
Old thread here:
The only ones I have dismantled have had rather well-disguised "sliding parts" that are simple...when you know how!
I'd say those connectors probably look like this removed
And would need a blade tool to remove similar to below, not a spike or screwdriver, as the end needs to make full contact at the bottom of the slot, maybe bend the tip slight to put more pressure on the connector.
As it's Rolls spec, they'll be pretty foolproof.
Super helpful. Thanks. Got a more robust tools arriving tomorrow so will see how I get on. The picture of the connectors definitely helps me get my head around his this may be jammed in there
Old thread here:
Thanks for the link!
Got it off. Thanks for all the advice folks! Turns out there wasn'y
I managed to get the connector eventually disconnected. It actually looks like the picture below. For anyone else's future reference dealing with 1980's Lucas Rists connectors, there is no 'prong' holding them in on the side of the connector like modern connectors. They actually have two small wings on the wire side that need pushing or pulling up, then the connector can be simply pushed through the center using a connector tool until it pops out the other side.
Hopefully someone will find this useful one day. Onto the next challenge - since these appear to be obsolete, I now need to figure out how to uncrimp the connector so I can reuse it! If anyone's got any good suggestions on this I'd love to hear them!
Reply to How to disconnect a Lucas Rists 1988 connector? in the Auto Electrician Forum area at ElectriciansForums.net
Hi there, I was wondering if anyone could advise me on the WT Henley Series 8 house service cutout. I have one of these installed at my house and...
I have unexplained equipment and diagram for three separate connected f81 connectors. Each f81 connector is connected to single receiver to single...
TLDR: In a 3 wire service are the ground and the neutral always bonded, in all subpanels? House made in 1970 has the meter and a 150 amps breaker...
I would like to ask advice on a breaker size. Back in 2001 I turned my garage into a woodworking shop with several 240v machines. To power them I...
