Discuss I'm currently trying to wire up a switch that power will be supplied to when i walk up to it using in the UK Electrical Forum area at ElectriciansForums.net
I think the problem I will have is that this sends a momentary signal. Is there any way I can turn that signal into a constant on?
You can latch a relay on when it receives a pulse from the remote locking module. How is it going to be un-latched afterwards?
A circuit that switches on the output when it receives one incoming pulse, then switches it off again at the next pulse, is called a toggle. There are various ways to implement this, e.g.
  • Digital logic such as. a J-K flip-flop, clocked by the pulses with the inputs both tied high
  • Ordinary relays; various circuits exist, some are more reliable than others, some require specific relays
  • Dedicated togge relays.
The last option is probably the most convenient although the toggle relays themselves are not common parts., e.g.
Reply to I'm currently trying to wire up a switch that power will be supplied to when i walk up to it using in the UK Electrical Forum area at ElectriciansForums.net
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
For power outages, my solar inverter (+battery) is able to take on the entire house load - as long as I unplug my collection of vintage kettles...
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
I'd like to find a timer switch, in a style that looks alright next to decora light switches, to control a bathroom fan. The bathroom fan...
Looking for a little advise as I’m not sure what’s happening So I’m looking at moving a two way light switch probably about 100cm away from its...
