Discuss Late to the party. Fusebox DB’s in the UK Electrical Forum area at ElectriciansForums.net
littlespark
Supporter
Patron
My local wholesalers have only recently stocked fusebox, so not had a chance to try them out with lockdown and whatever.
I fitted a garage board not long ago to supply a hot tub, and used fusebox to match the main db, but today was my first swap out.
Conditions couldn’t have been better. Not too high that I needed steps, and not too low that I had to lie on the ground.. eye level.
Everything came in from behind, tails came from outside meter box with service isolator. Even better, no need to summon a seal fairy.
Old MEM with the push button circuit breakers. The old switch fuse above is for non existent storage heaters, but is staying as its tails are still connected to teleswitch. No fuses fitted.
New board up. All RCBO on 6 circuits. There is a new shower circuit going in soon, so I’ve left blanks between the breakers and mainswitch to slot another RCBO in.
Not my tidiest work… but I like that the board comes with ample space above RCBOs, and clamps for the tails.
Has a slight lean, but not as bad as some brands.
Just needs stickered up now.
Is it just me or at first quick glance it looks like MK with that MK lean
I did mention the lean earlier… but not as bad as mk. They move when tightening the RCBO top terminals.. too much leverage against the din rail. And that’s using a torque driver… (no impact for me!)
Could manufactures not have a guide built into the box, like the bracket for the cable clamp, that would sit against the rightmost module.
I suppose if you fill the board with blanks, you could have one on left side as well.
Copyright Littlespark. I’ve called it!
Do you have any bother with the grommet strip for the rear openings?
The little tabs closed up when trying to get round the corner, didn’t slip over properly. Kept poking at it with a thin screwdriver to get it to open up enough.
Not really noticed to be honest. I think I usually put them on from the back with the box gutted.
I like that the knock outs actually knock out!
Reply to Late to the party. Fusebox DB’s in the UK Electrical Forum area at ElectriciansForums.net
Local funeral place is getting a new mortuary fridge unit, and needs some work done. The CU, just for the room, is high up in the corner, just...
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
  • Locked
5K
Hi everyone, I need help installing a Lorex smart doorbell. I have tried to install a doorbell transformer several times to no avail. The first...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
