Discuss Lead washer inside or outside in the Electrical Appliances Forum area at ElectriciansForums.net
Are you on about the brass earthing washers for SWA glands?
If so them I have seen them fitted may ways.
Some on the outside with a bolt through the washer & enclosure.
Some fitted inside with a bolt through the washer & enclosure.
Some fitted inside the enclosure with the tab bent and a bolt through it.
Some fitted inside with a brass lockwasher either side of the washer.
As one of the guys at work would say "There are many ways of f****** a pig"... Not to be taken literally.
Lead washer between coupler and accessory, but it must be a flanged coupler.
I'd assume they are talking about the lead washer which comes with a flanged coupler.
In which case the answer is between the coupler and the enclosure as it is there to form a watertight seal.
Yep. Thought I'd got it wrong when Lucien posted.
Just been talking about SWA glands at work and had it stuck in my head.
Reply to Lead washer inside or outside in the Electrical Appliances Forum area at ElectriciansForums.net
I have a small power washer with a two-wire cord and GFCI plug. My outdoor and garage receptacles are on a "house GFCI" circuit, wired in series...
Hi, We’re having problems with our Bosch serie 6 washer/dryer. It’s about 6 years old. The model number is WVG30461GB/03. It has begun to stop...
Hello, I have an all-in-one washer/dryer unit and it is giving me error codes. I have the manual that describes how to test the various...
Very appreciated forum. Washer earth trips RCCB unless it is rocked back & forwards aggressively. This is a struggle. One brush had worn...
Hi All. What is the best/preferred method when connecting 20mm conduit to a back box of a socket on an outside wall ? I am connecting a BG...
