Discuss Light switch replacement in the DIY Electrical Advice area at ElectriciansForums.net
Soxfann18
I am replacing a single pole switch that controls two light fixtures. Seemed easy enough, the old switch had two black wires that were connected by backstabs and a red wire that was connected by the screw on the side. After replacing the switch, one light was controlled and the other was on all the time. I tried connecting the two black wires together by pigtailing with a third which was connected to one screw and the red one to the other. Any help would be awesome
Sounds like one of the black wires is the permanent live in, and the other black and the red should go to the lights.
Connecting the two blacks together has resulted in one light being on all the time.
You probably need one of the blacks and the red together. If you try that and you get the same effect as at present, that's the wrong black!
Can you show the old switch and where the wires were connected.
Avo MK, thank you. That was the problem. After rewiring with the red wire pigtailed everything worked. I guess I'm just used to red being that color for a different reason (load, power, etc.)
Reply to Light switch replacement in the DIY Electrical Advice area at ElectriciansForums.net
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
Hi, I am installing a new bathroom fan. We had an electrician who ran 14/3 into a junction box. The black feeds a led light and the red was...
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
Hi, in my bedroom i had a 2 gang dimmer that powered 2 set of 3 spot lights and also had passthrough wires to other sockets. Im changing to just...
