Discuss Measuring Direct Current with Fluke Multimeter? in the Electrical Tools and Products area at ElectriciansForums.net
I've been told I need to wire the multimeter in series with the LED I'm trying to measure. I tried doing that and now the COB won't power on. I made a diagram for the wiring when I initially successfully wired up the LED so I'll post a picture of that below along with pictures of my wiring.
Diagram: Upload the image directly to the thread: The most awesome images on the Internet - https://Upload the image directly to the thread.com/KfMS8iY
A/C In: Upload the image directly to the thread: The most awesome images on the Internet - https://Upload the image directly to the thread.com/d6aVoyk
D/C Out: Upload the image directly to the thread: The most awesome images on the Internet - https://Upload the image directly to the thread.com/Fs0ZXFe
Multimeter to LED: Upload the image directly to the thread: The most awesome images on the Internet - https://Upload the image directly to the thread.com/JyVDS6P
Any help would be greatly appreciated.
Edit: Also going to add a picture of the diagram I'm trying to replicate.
Upload the image directly to the thread: The most awesome images on the Internet - https://Upload the image directly to the thread.com/a/8Ewbi
If the COB does not work when the meter is removed there is a circuit fault, if it is only when the meter is in place then a fuse may have gone in the meter, the start up current can be quite high on LEDs and the meter may not be rated for that.
Reply to Measuring Direct Current with Fluke Multimeter? in the Electrical Tools and Products area at ElectriciansForums.net
Hello everyone, friends. In cases where I do not have a clamp meter, I want to measure the current drawn by the phases of a 3-phase motor with my...
When I use Fluke multimeter clamp-type [true RMS meter] to measure AC current in a 3.5C XLPE cable, does it give the value of leakage current or...
I’ve got bad ballasts and am replacing the T12 fluorescent bulbs with Halco direct wire, double ended T8 LEDs. The fixture has 4Rapid start bulbs...
I'm encountering a problem with the lighting in my kitchen. I reside in an apartment that has a light fixture utilizing 2 T8 fluorescent bulbs...
Hello everyone. Budding DIY enthusiast fascinated with how things work - and, to a lesser degree, fixing things that are not working. I suppose my...
