Discuss Melting adaptors in Mauritius in the UK Electrical Forum area at ElectriciansForums.net
Hi people, I recently moved to Mauritius which has a UK 3-pin plug system, however the vast majority of appliances on the market are imported from Europe and therefore have European 2 pin plugs on them. As a result everyone here runs all their appliances on block plug adaptors and extension cords (silly I know)! Up to last week I hadn't had a problem but I just bought a small Rowenta space heater (yes it can get a little chilly in the winter!) and since then it has melted 4 of these plug adaptors (see pic). In none of these melt instances had the heater been running for a long time. So, does this suggest there is something wrong with the new space heater, or is it just not safe to run them on an adapter like this? Can I simply cut off the Euro 2 pin and wire on a 3-pin? All advice gratefully received!
Wouldn’t trust those cheap Chinese adaptors. Much better to install a fused 3 pin plug to your heater.
It shouldn't be an issue using an adapter with a heater.
I don't see any CE markings on that adapter. An the way the pin has deformed suggest a poor quality product.
Is this a multi way adapter? Have you other items plugged into it?
Thanks for the comments. All of them were multi way adapters but nothing else was plugged in at the time they melted. Sounds like you are both suggesting that the adapters might be to blame. It can be hard to find high quality supplies here but I'll see if I can track down something with a safety mark on it and give that a try.
Reply to Melting adaptors in Mauritius in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Hoping someone can shed some light on this, i have purchased a surge protector and it will not fit the power cables i plan on using. I...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
Hello, I'm seeking some advice on an overheating plug adaptor please. Complete amateur so please forgive any errors in calcs / assumptions /...
I'm in Raleigh, North Carolina and have a well for my house's water supply. For some reason, pitless adapters, which allow all piping to be run...
Hi, I hope you are all doing well. I have original UK samsung, apple and Huawei plugs and would like to know which combination of plugging them...
