Search the forum,
Discuss minor works cert in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
BristolSpark
Can someone please clear my mind. If you were to install say two additional sockets in two rooms of the house. Do you complete a minor works for each room or one for each circuit if the sockets were on different rings.
The same question effectib=vly applies to lighting circuits.
Adivce would be great. Cheers guys
so if there is 5 additional sockets on one circuit issue one cert
if there is 5 sockets on on different circuits issue a cert per circuit.
would you take the worst result of the additional sockets for the readings on the cert. ie the furthest point.
Reply to minor works cert in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Evening all, I just wanted to see if electrical improvers/adult trainees with appropriate levels of experience and who hold testing...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Good morning, We have a two-bedroom flat that my wife and I rent out to supplement our income. Following the recent EICR, several issues...
