Discuss Multimeter testing - help in the DIY Electrical Advice area at ElectriciansForums.net
Dornex
I'm new here and by no means an electrician.
I was left a fluke 902 by my neighbor who moved out. I just wanted to test it if it works but when checking AA batteries for example it gives me different readings when I reverse polarity. The same battery shows 1.2 and -1.5 when turned around.
Any ideas? Any recommendations on how should I test if it works properly?
Its device that might need calibration or new batteries , contact Fluke UK.
You just tested if it works properly, evidently it doesn't if it measures a different voltage just by reversing the polarity. I assume you repeated the test?
Change the internal batteries then try testing a different (new) battery and maybe try a new set of test leads, however you can't check if it's working properly unless you compare it to known good device or use a calibrated voltage or current source.
It is designed primarily for HVAC work (and by the way you can't check batteries are OK with a voltage check alone).
think i'll go back to bed.
yep. and i haven't even got started yet. just to kick it off.......
Not quite as bad as the first one, was that another Month send up ?
I bloody hate predictive text, should have read another Monty Python send up.
mel brookes. king of american comedy.
finding life is hard to cope
at the end of a telescope
the future is hard
like stirring lard
the birds call out
i twist and shout
nobody hears
my hard pressed tears
the way to life
is all through strife
let me have your dedicated ear
now it's time for another beer..
and that, folks is my first ever attempt at poetry.
Aah right, don't watch much modern stuff. Prefer things like Steptoe & son, Only fools & horses etc.
have you never watched the film, blazing saddles?
Reply to Multimeter testing - help in the DIY Electrical Advice area at ElectriciansForums.net
Good afternoon, I have a 2 year old car battery (AGM 760 CCA) in a 2022 Hyundai that constantly "seems" to lose its charge. I'll check the...
The MS8268 multimeter has worked fine with no issues, but it's been in a drawer for several months. Batteries had corroded, but the contacts...
Hi, I need some advice on the wiring for a new ceiling light. I have taken down the original light, and I'm left with the wiring in the image...
So I have a outlet protected by a gfci breaker, and if you use the plug test the gfci doesn't trigger . I replaced the gfci breaker and the...
Hi guys. I posted yesterday about a suspected faulty starter motor.. I've had the starter out and cleaned everything up and all seems to be...
