R
ridemx27
hi i dont believe there is any rcbo available as a retro fit to my knowledge but correct me if im wrong, im sayin they are wylex retro fit mcbs goin by the fact pip said they have a round push in button to reset which was the early type of retro fit mcbs. the unknown 15a in cu no1 is prob goin to be immersion or a radial. neutral and earth is always shared on dual tariff usally all go back to a service block and met thats fine. 1 rcd would be acceptable for convectors, split load prob not an option due to size of board and little room as u say and tbh not really needed, best option is 6 way cu with 4 rcbos but thts around £150 as appose to around £ 50 for 6 way with rcd no main switch needed use the rcd. you will need to feed the new cu from cu 1 as before in suitable size cable prob 4 or 6mm and will have to be put on cert as distribution circuit and tested like all other but will not require rcd protection so existing mcb should be fine, im trying to picture in my head with what your telling me so without seein there could be things im missing, this should be a run of the mill task for an electrician if ur unsure i would say leave as it is and put a plug in convector heator on the wall near a socket ( as a cheap landlord freindly solution) not corret tho i no, and maybe discard of the storage heater if neccesary
