Discuss Noisy LED lamps in the UK Electrical Forum area at ElectriciansForums.net
HandySparks
Mentor
Just installed 12 light fittings an a new house. Most using several G9 LED lamps. I was surprised to find that there was a distinctly audible hum from many of the fittings. These were ceiling lights consisting of a large thin chromed steel disc fixed via a bracket to the ceiling and supporting closely fitted G9 lampholders.
On a different type of fitting with several pendent G9 lampholders, the noise wasn't audible when fitted with the same lamps.
I'm guessing that these lamps have some vibration in use and that the large metal disc was resonating and amplifying the noise. Has anyone else come across the problem of noisy LED lamps?
The lamps in question were all 'integral LED' 2.5W, 160 lumens.
The LED lamps were bought direct by my customer from the retailer of the fittings and supplied as suitable for replacing the halogen lamps normally fitted.
mine was a buzz- but swapping to varilight dimmers cured my problem
this sounds (pardon the pun) like more of a 'physical' noise- vibration??....
Reply to Noisy LED lamps in the UK Electrical Forum area at ElectriciansForums.net
I am looking for some buying advise. I wish to change all the existing incandescent lamp fittings in my house to LEDs. Each of the bedrooms will...
Recently moved into a new home and replaced the main light fitting in the sitting room. We replaced it with this dimmable LED fitting: ENDON...
Hi - I'd appreciate some advice please. I've just replaced all our G9 Halogen bulbs in the fittings in our living room to LED versions - 16 in...
