Discuss Old Wylex Board in the Industrial Electricians' Talk area at ElectriciansForums.net
L
londonelec
I have a job where a customer wants me to test the whole installation but does not want to upgrade it to Dual RCD 17th edition and this board is an old wylex board with the later type MCB's added.
I have to add some lights but they are already in place just need to change them from pendants to something fancy maybe ?
I am not doing anything major but they want a cert and i am not sure if i can cert this board now the 17th edition is in place because normally people accept the regs and have a new board fitted and i cert it.
Can anyone tell me what to do in this situation ?
Thank you.
Please excuse the iffy typing just got back from the pub! A PIR is just an inspection of what is there not what should be there to current instructions. Report what you see (list of inspection) with what you measure (schedule of results) and give your, or a guided opinion, on that. old mcbs might do it, don't write them off, they just aren't up to modern scratch. If you're only changing fittings not in a special area, as long as you're not breaking current regs, I think , change away!! If they're metal bodied and not double insulated they must be earthed, apart from that off you go!! BUT if you test the whole of the install if anything doesn't come up to par with pre -energised tests I would refuse to do any more until that is rectified and charge him for your time.He or she has got you in to test what he considers a safe install ( refusing the educated offer of an upgrade indicates an acceptance that all is safe to installation standards be they 16 15 ) best of British!Be careful out there
Thank you i thought it was OK to test its just normally people accept that the 17th edition boards are safer and want them installed.
The wiring looks a little tatty in the CU but i will tidy it up but there is nothing that stands out as dangerous on my first glance but the test will tell me everything. But one thing there is no existing schedule so cannot compare i can just give my Periodic Inspection.
Make sure that he agrees that all you are doing is testing the install not ensuring that it meets with current regs. As I said , give him an inspection cert and a schedule of inspections after he's paid you . Job's a good'un!
Reply to Old Wylex Board in the Industrial Electricians' Talk area at ElectriciansForums.net
Been asked to move, remove and add some sockets the kitchen and I’ll need to add a circuit for an electric hob. Looked at the board and it’s one...
Hi I always thought installations were safe at the time of instalment etc, the Distribution Boards at my works were installed over ten years back...
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
Hi All I'm new here. I have just finished my NVQ and waiting to do my AM2. I have a question on selectivity as it has always slightly confused me...
