Discuss Overclocking a solar inverter? in the DIY Electrical Advice area at ElectriciansForums.net
Banosprof
Hi. I am going to have a solar power system installed and it will include a 13kW battery and a Zappi charger to use with my electric vehicle. The Inverter is spec'd at 3.6kW, which I think is consistent with what the grid will allow. I've been looking into now many solar panels to have and thinking about overclocking (oversizing) relative to the inverter. I've seen that getting solar panels up to 130% of the inverter spec is Ok but above that it may shorten the inverter life. How high should I go in solar panel power? Any and all comments welcome. Thanks.
Anything that begins with an over- is bound to reduce the lifespan of a product. Adding more panels will be a waste as the excess power will not be used and the inverter will trigger an OCP shut off or burn a fuse if the AC load exceeds its maximum rating.
Also, adding more panels won't charge the battery faster if the Vr only allows for say 20A@14V or increase the amount of AC you can pull out of them using an inverter.
If you REALLY need more than 3.6kW get a bigger inverter.
Source?
Been thinking of getting a panel to power some lights DC only with no inverter so I'm also investigating.
Reply to Overclocking a solar inverter? in the DIY Electrical Advice area at ElectriciansForums.net
Electrical2Go - Green2go Launches for All Your Solar, EV Charging and Renewable Needs Green2Go - for All Your Solar, EV Charging and Renewable...
I am a Napit registered electrician and want to get into Solar PV and battery storage. I have boot camp booked in April but am not hearing good...
Hi,first off this does not relate to work I intend to DIY. I'm trying to sanity check information I've been asked to provide to the installers. I...
Hi all. We have had 7x 400w solar panels for a number of years now on our roof which is se/nw facing end terrace. 4 on se side 3 on nw side...
