Discuss PWM circuit help in the Australia area at ElectriciansForums.net
T
tkhao1986
Hi guys, need some help for the 12V circuit as circled. Basically, i have a pwm output from the microcontroller which will control the ON/OFF of the MOSFET Q2, linked to the 12V battery. As i adjust my potentiometer to control the duty cycle, the voltage between the load doesn't seem to change. If all goes according to plan, as i adjust the pot, the voltage between the load should change too.
And with this circuit, i believe i may also have some problem with the floating voltage at the gate of the MOSFET Q2, correct?
Reply to PWM circuit help in the Australia area at ElectriciansForums.net
hello guys i have a (3-6v dc motor), (DC Motor PWM Speed Controller 3V 6V 12V 24V 35V), (3.7v 1200mah rechargeable battery) and a (Charging /...
Hi, So I'm replacing a small old off grid with a new 7.5kw off grid, & being poor seek best value for my mppt, after long searches I find this...
I'm sorry if this isn't in the right place but this is my first time using this forum. I'm also sorry if i make some mistakes but I'm new to this...
Hi! Some help would be appreciated! I've just moved into new house, wanting to check insulation resestance etc as getting some nuisance...
I’m planning a 240V welder circuit in a detached garage with a 100A sub panel. For the 160A or 180A output welders I’m looking at, the conductor...
