Discuss radio / stereo DAB...PLEASE HELP in the Auto Electrician Forum area at ElectriciansForums.net
tonytee
Hi I have a shark antenna for my car and It has DAB (digital radio) but my car stereo does not have a DAB socket to connect to it. I have heard that I can connect it via the FM connection (not sure if this is true or not) but if so, can someone please send a link to the adaptor I need to buy so I can get DAB in my car.
Many thank for your help in advance.
DAB is a completely different protocol to FM radio. You need a DAB receiver to decode the digital signals.
So you either need to replace your radio, or buy a DAB converter, which will turn the DAB signal into an FM one, so you can plug the DAB converter output into the FM antenna socket on your current receiver, and tune to its channel.
Then you choose the station on the DAB converter, and your FM radio stays on the same channel all the time.
Either option will probably cost about the same.
There's no cheap way of doing this as far as I know 🙁
Reply to radio / stereo DAB...PLEASE HELP in the Auto Electrician Forum area at ElectriciansForums.net
Afternoon All, Just pricing up a job and thought I'd pick your brains. Quick run-down, Block of Flats with an underground car park. In the...
Hi all, hope someone can help 😊. I am looking at running a transformer extension lead behind my dot dab plasterboard wall. My wife bought a Led...
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
The symptoms its been having to start with was the fuel gage only working sometimes and when i play music from my phone when a loud song came on...
I appreciate that @mark641 asked how ferrite cores work here, answered by @Lucien Nunes , but TBH, it is at a deeper level than I need. My...
