Discuss Rcbo memera 2000ad in the Australia area at ElectriciansForums.net
W
webby_58
Hi all,
Can anyone help me find the correct part number for a 16amp rcbo to suit an older memera 2000ad CU.
I seem to keep coming up with conflicting part numbers.
Your hopefully......
MEM Legacy Information:
If you are replacing a ADxxB MCB where xx is the nominal current rating:
16A, Type B, RCBO, Part No. AD16BH30
However, if you are "replacing" a ALxnn1 MCB where x is the Type (B, C or D) and nn is the nominal current rating:
An RCBO pod can fitted to the existing MCB (assuming the nominal current rating is correct) to convert to 30mA, RCBO, Part No. AH30. Therefore ALB161 plus AH30 makes a 16A, 30mA, Type B, RCBO
Later:
MEM AH30 RCBO Pod was discontinued before Eaton rebranding. Replaced by either MEM AD16BH30 or ALB161H30 16A, 30mA, Type B, RCBOs, Type C and D also available in the ALx161H30 style.
Eaton Current Information:
MEM AD16BH30 and ALB161H30 replaced by Eaton EAD16BH30 16A, 30mA, Type B, RCBO, Type C also available EAD16CH30, Type D not currently available.
Reply to Rcbo memera 2000ad in the Australia area at ElectriciansForums.net
Hi All, I am a fairly experienced electrician in both installation and maintenance in both domestic and commercial environments (5 years). I am...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Background I live in Indonesia, the voltage for residential buildings ranges from 220 V to 230 V, I need help with the installation of the...
Hi friendly people, As you may be aware, I'm a plumber, so quite possibly what I am seeing is correct, though it seems a bit odd to my untrained...
5K
Over the last few days, I have stumbled across a number of threads that seem to point to a prevalent misunderstanding. Either that, or I have been...
