A
Ali
Hello guys,
I bought a 2015 E-XL accord with an accident on the driver side.
After I got the car ready from the body repair shop, I noticed that rear windows are not working at all. I haven't checked the windows before the repair because the driver door was completely removed.
I took it to different auto electrician but no one could figure it out.
Any ideas?
Hello guys,
Any ideas?
Fuse gone
Broken Wire
Relay
Bad connection
Bad Earth
Did you have the window replaced
The list is endless Ali
The Auto Electrician wasn't much cop was he ?
The switches themselves are prone to biting the dust,remove the connections and link them out where needed
I'm not familiar with this particular car, but a lot of modern cars have the windows and locking system controlled by a computer in each door/spread around the car. So if all connections are good you may need someone with a diagnostic tool to reprogram the modules. Perhaps the drivers door was replaced with a new one?
a bitter fresh air will not arm any body except -15deg
Fuse gone
Broken Wire
Relay
Bad connection
Bad Earth
Yeah, he wasn't that confident to play with a new model car.
yea you are right, the front door was replaced completely with a new one.
This is interesting to know, I would take it to a real electrician with a diagnostic tool (pray to find one).
I will keep you updated.
Ali , to be fair to your auto electrician ; and as @Pete999 has said ,it could be anything .
Has the car been on a jig , welded, or just had plain rough dismantling?
The harness could be damaged through the door pillars, are the rear windows allowed to be isolated from the drivers controls? The list goes on .
Damaged repairables can be a nightmare , especially as has also been said - the all singing all dancing new stuff.
Or it could just be as simple as neglect to refit a multiplug.
Never a good idea to throw parts at a job until you have proven the part is faulty. What are we referring to here, a rocker switch? Power in = power out. test it don't guess it! Costs too much money.
rear windows not working, Accord 2015
Auto Electrician Forum
Ali,
Auto Technician,
