Discuss Remote Control Light Switches in the Australia area at ElectriciansForums.net
Or you could always put a surface mount switch lower down the wall and run the cable down from the existing switch in some mini-trunking, blank off the existing switch point. Take about 10 mins and cost about £2!! Can also be restored aferwards when daughter has grown a bit.
I just got a few cheap step ups for wilko for £3 each. Also extended the bathroom pull switchs. 2x daughters switching happily away.
Ebay
Item number: 330672904776 i got one in my sitting and you can set it up yo use a button off a tv or sky remote that you dont use i use the blue button off the sky remote works perfect.
Reply to Remote Control Light Switches in the Australia area at ElectriciansForums.net
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
Hi, I am looking to convert a 2 way light into just control by single switch. I have searched and looked for similar questions here, and found a...
Hello, I have installed 6 recessed lights in my living room as well as wall boxes. I’m now at a point where to need to run the wiring. I plan to...
I've purchased Lepro 15m LED strip lights - product code PR410047-RGB-UK, and have fitted them at the top of the walls in my daughter's bedroom...
What is the oldest dimmer switch you have seen in use recently? When did you install your first dimmer? (Veteran sparks only) I ask because a...
