Discuss Replacing a single socket in the UK Electrical Forum area at ElectriciansForums.net
Jaymorris
Probably going to get slaughtered for this, but I took a single socket off this to replace with another single socket that was smashed, but I was met by all of these wires and some require for lives to go into one hole which is proving impossible considering that’s how it was wired in the first place. Any ideas how of what I can do? As I’ve left it like this for the time being, the sockets on the same wall no longer work. Any help greatly appreciated
quite Simpley,
What you have there is Wrong.
A bad install and against reg's
the maximum amount of cables you should ever have on a socket is 3 per terminal.
ring in
ring out
+ 1 spur at the most.
i think you need a profesional to sort out the underlying problems before trying to bash a new socket face on.
p.s. make sure that the circuit remains turned off at the distribution board.
Is that 4 in each terminal? No wonder its tight.
There looks to be another point on the right, sitting on a surface pattress box. That might be your answer.
Make a joint in that back box and just bring one set through a pattress and into the socket.
Actually, it looks like the item on the right is fed from this socket. It could be rewired better to lessen the amount of cables at one point.
Well the sockets no longer work as you have basically interrupted the feed to them and by leaving it in the present condition you are leaving it in a highly dangerous state as live wires can be access !
Judging by the newer cable colours someone has already taken a spur from that socket or is that the wire that you have installed for your new socket outlet ?
I would immediately switch the supply off at the consumer unit(fusebox) for that circuit until you can get it rectified
quite Simpley,
ring in
ring out
Thank you for such a quick reply. Annoyingly If i turn it off it turns off all the plug on the first floor of my house. I know it’s super dangerous to leave it like that, but I have no choice until I can get a pro out
I haven’t messed with the wires. I took the old socket off and that what I was met with. Four wires going into one hole. Four neutral and four live. Can’t tune it off as the other sockets in the house go off.
Reply to Replacing a single socket in the UK Electrical Forum area at ElectriciansForums.net
Have a single plug socket which has been working fine for years. It is behind a unit so nothing has hit it. I looked at the socket and can seen no...
Hello I have some decking lights which to be fair, have been nothing but pain in the bottom since they were installed. Moisture in the lens lamps...
Hi all. I'm going to replace some sockets during a routine redecoration of our lounge including replacing some singles with doubles with USB...
hi. would appreciate advice from any electricians. am trying to replace a 13amp [35 year old MK] wall socket but the terminal cage in all the...
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
