Discuss Replacing LED Driver in the Lighting Forum area at ElectriciansForums.net
rdswisher
Hello, my vanity fixture LED driver needs to be replaced. It's constant current with output 25-38.5vdc 600mA max 45v no load. I can't find exactly the same driver. The driver with 24-36vdc 600mA resulted in flicking. I'm thinking about going down to 450mA with 21-43Vdc. Will this work?
as long as the load current is below 450mA OK. what is critical is that the max.output votage must be equalto or higher than the original. i binn caught out with that once before.
i'd go for the 25- 41V myself. it's the LEDs that determine the current, not the driver.
Reply to Replacing LED Driver in the Lighting Forum area at ElectriciansForums.net
Hey folks, i work for a relatively small company, but we are doing some big jobs. And right our headache is taking over outdoor lighting...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
Hi all. Slightly out of the ordinary, but I'm looking to replacing between 60 to 100 standard size E27 bulbs with LED equivalent. The catch is...
Hello, I’ve have some ten year old Collingwood SL020 RGB led garden spike lights which I’d like to keep using but wondering if I can use them with...
Hi Forum people. First time post here. I have a pair of semi flush fittings that are currently 10 Halogen capsules per fitting. I want to...
