Discuss Running a heavy duty food mixer with adapter in the UK Electrical Forum area at ElectriciansForums.net
ttarrant4
I need to buy a larger mixer for my small bakery, but I only have standard wall outlets and an oven outlet (pictured); the mixer has a NEMA 6-20 plug. Can I safely run a mixer with the ratings indicated in the attached spec sheet using an adapter to either the normal wall outlet or the oven outlet? If I can, are there any other factors to be considered? I know next to nothing about this kind of stuff. Thanks! (Oven outlet says 125/250V and 50A)
My advice to you is I don’t really have enough information to really help. What HP is your new mixer and Is the mixer dual voltage ?
Is there no way to delete or even edit a post? The rep I was speaking to about this mixer was wrong about the type of plug it used; it's just a standard wall plug so my question doesn't need to be up anymore.
Reply to Running a heavy duty food mixer with adapter in the UK Electrical Forum area at ElectriciansForums.net
I have an existing but unused 50A disconnect on the side of the house. It had been connected to an AC unit that got replaced. It has just 3...
Hello, new here! Would greatly appreciate some input. I'll first say I intend to get an Indesit technician to take a proper look tomorrow, but...
Hey folks, I had a couple of questions regarding running electrical cables in an attached garage. Any help is appreciated. #1. I am installing a...
5K
Ok Hello all and thanks for having me. I need some advice and joined this forum hoping to be pointed in the right direction. First off I am not...
4K
