For fixed appliances in a bathroom the isolators are normally fitted outside the bathroom, obviously inside the bathroom is not an option.
Now you just have to consider whether the mirror you have is a light fitting or a fixed appliance to establish whether it would require a local isolator.
Normally I would take a lighting feed to it without an isolator, the same as you would for any light fitting which requires a permanent live.
