Discuss Service point in out building in the UK Electrical Forum area at ElectriciansForums.net
Hi there.
My friend is building a new house. He has decided to put service point in and out building next to new house. A duct has been run from out building to house. I will be using 16mm three core to supply house db. I've decided to use rcbo's for circuits in the house. But I am unsure if the cable at the out building side should be rcd after the cut off to supply the house? Any advice would be appreciated.
Two things:
1) Check your calculations for voltage drop for the lighting - you might need to upgrade that 16mm to a 25mm depending on length of run
2) It would probably pay you to bring the incomer into a metal-clad consumer unit anyway as that way you have something to make your armoured off to and also can run some ancillary sockets and lights in the outhouse more easily.
No, you don't need to provide upstream RCD protection to the cable, but personally I would install it onto a DP MCB rather than a single.
1 and 1/2 storeys? must be DIY as he's already demolished half the upstairs. :drool5:
The half storey is built in the roof space with dormers!!!
sounds like some sort of hobbit hole..........
what the hell are you building over there ? lol.
MP: Shoe box?
TG: Aye.
MP: You were lucky. We lived for three months in a brown paper bag in a septic tank. We used to have to get up at six o'clock in the morning, clean the bag, eat a crust of stale bread, go to work down mill for fourteen hours a day week in-week out. When we got home, out Dad would thrash us to sleep with his belt!
GC: Luxury. We used to have to get out of the lake at three o'clock in the morning, clean the lake, eat a handful of hot gravel, go to work at the mill every day for tuppence a month, come home, and Dad would beat us around the head and neck with a broken bottle, if we were LUCKY!
Reply to Service point in out building in the UK Electrical Forum area at ElectriciansForums.net
  • Locked
My house was built in the 1930s, The fuse in my service cut out is 60Amp and the wire coming from the street has a 16mm2 copper core(easy to see...
Good morning all, I am currently working on a House in Multiple Occupation (HMO) consisting of 10 flats, with three parking spots equipped with...
Hi All, I have a client who is developing a plot of land for a single house. Currently, their 100 amp service cut-out is in a cubicle fed by...
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
Good morning all, long time reader first time post so looking for some help I’m qualified as an electrician but haven’t worked as a sparky for...
