Discuss Shower isolator switch misbehaving in the DIY Electrical Advice area at ElectriciansForums.net
P
Phthalo
HI Guys!
Newbie here with an isolator switch question:
The isolator switch in question services a domestic bathroom shower unit and yesterday it just stopped working. The red light does not come on when the switch is flipped it and in turn no power to the shower unit. The odd thing is that the shower circuit switch on the main RCD has not tripped as I would have expected. I hope this is enough info on the issue.
Any clues as to what may have happened?
Thanks in advance
Phthalo
Are you talking about the RCD or the mcb?
This would be the main household circuit breaker unit on the wall (if that helps).
probably a worn out switch/isolator. could also be burnt through terminations. best get a local electrician the ensure that any repair is done safely.
If the isolator switch has just failed to switch then this would not trip a breaker or RCD.
as usual .DIY OP done a runner.
Thanks - I had an inkling that might be the case. So I may just need to replace the the switch.
Reply to Shower isolator switch misbehaving in the DIY Electrical Advice area at ElectriciansForums.net
This could possible have been a poll, but really just opening up for suggestions and feedback on where folks think an isolation switch for an...
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
Hi guys, I have recently encountered that my circuit breaker for the upstairs lights keeps tripping. I flick it back on and immediately it trips...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
I had Scottish Power moving a supply this morning from one building to another so an extension could be built. I had everything ready for them...
