Discuss Solar AC side in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
K
karmannmann
I am doing a solar install and on the ac side i have a 20 amp triple pole isolator with no diagram in the box, i have L1 L2 L3 at the top of the rotary switch and T1 T2 T3 on the bottom and earth terminals either side can someone tell me where the lives and the neutrals go ?
You'll need to enlist the help of an electrician to connect and certify the installation. The isolator you describe is designed as a three phase isolator. If you incorrectly connect neutrals to it you will damage it (and possibly yourself) beyond repair.
Aye, it is a requirement from the DTI PhotoVolatic in buildings doc (section 2.3.2) that the Line & Neutral be switched.
I had the same quandry with a Kraus and Naimer 20A switch which was defo for single phase but had 3 connections and an Earth. The K&N wiring diagram just showed that L1 goes to T1, L2 to T2 etc. I figured it didn't matter as long as it was consistent (we had two AC isolators).
Lol, I think he's talking about using a 3-pole isolator for a single phase supply.........I hope.
This thread was from three years ago.
In all fairness, Paul, no one installing electrical equipment should need to come on to a forum to ask such a basic question. Electricity is dangerous and training is absolutely vital.
Why are there so many people on here that make comments like this if someone is doing an unusual job for the first time and needs a bit of advice. It comes across as really arrogant my friend
gordon bennet. if someone don't know how to connect a simple isolator, electrical work is not for them.
Reply to Solar AC side in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi, Trying to wire this 3phase switch as single for a table saw, told I could do this from guy at Haymans, even told 2nd time which wires to...
Hello All Can I say to start with I am not an electrician but used to be a heating engineer (yes I can hear the groans). I have wired the...
14K
I'm in a questions asking mood tonight. I briefely looked at a job today and I need to recommend a board change but need to justify it. Firstly...
I have a main panel beside my meter on the house built in 1987. Then a 4 wire feed into a 200 amp panel on an inside wall of my basement. All of...
I have a scenario where there is a three phase DB in a commercial property where there are mixture of three phase and single phase washing...
