Discuss Solar Edge and SMA Inverter?? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
V
VMan
Hi guys,
I've only recently stumbled upon these Solaredge power optimisers, Seem good and thinking of adding them on half of my array as they have shading in the winter months, so..
i have a 10 panel array, 5 with shading in winter months,
Can i add 5 power optimizers for 5 panels and add them to the array string, or have all 10 modules with optimisers and put them into a sunnyboy? or must they be used with a solar edge inverter?!?!
I' not too sure how they work, i'm thinking they are a DC/DC micro inverter with own Mppt? then set a constant voltage output? #
Anymore info would be great on these.
Hi V'man,
I was sub-cont' installing SolarEdge systems in the run to 12th Dec. The inverter has to be "paired" to the power units~ at first start up each unit sends 1 volt (ie 10 modules = 10V) and then inverter pairs it self to each one. How I don't know (SolarEdge technical manual gives nothing away), possibly sending digital signal~ then when running the inverter reads each one and aligns the DC line voltage to suit best production. Without the SE inverter, each optimiser would be at different voltage (that is if it would even initiate) so guess could be worse output on SMA~ poss' even cause burnout of optimisers.
One question for anyone with more info~ you cannot test for a string Voc/Isc so what do you do for string tests? has anyone run this past their accreditors?
thats what we do!
Solar edge are better system than SMA but cost a little more.
We have installed over 40 solar edge system in 2011 and all customers are happy with results
With solar edge the optimisers are trackers, so you have a tracker per panel and none in the inverter (as I understand it) which is why you have to have the solar edge inverter to go with the solar edge optimisers. Price differential doen't come out too much - you pay more for the oprimieers, but the inverter's quite a bit cheaper
pj
Reply to Solar Edge and SMA Inverter?? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello, My current 2.5kW Solar pv array is in a less than favourable position, but there is plenty of space to expand the array. I have an...
TLDR - I have a system that is supposed to have optimisers fitted, but I am not sure they have been fitted. The detail: Back in March I had a...
Greetings, everyone, After dedicating over a month to researching Solar PV systems, I'm nearly ready to make a decision. I owe my progress to...
I (well, the MCS installer) obtained approval under G59 back in 2015 for 11.5 kW of grid connection on a single phase. 12kW of panels into two 6kW...
Hi all. We have had 7x 400w solar panels for a number of years now on our roof which is se/nw facing end terrace. 4 on se side 3 on nw side...
