ESP is a system designed to help counter a loss of traction on the road. Another commonly used term for such systems is ESC (electronic stability control). You'll find different manufacturers have their own names, but most systems work in a very similar way
Mitsubushi's AYS was unnerving. Just as the car should have been headed sideways it suddenly straightened itself. Downright dangerous I thought.
I only know about the use of a LSD not necessarily on a car. 🥳
  • Funny
Reactions: nicebutdim
Teenage years in the 60's where really something you had to be there.
It's not clever shutting down all the tail lights on a trailer without a very visible dash warning, even if it is protecting the vehicle wiring. Could lead to a very nasty rear end collision.
If a lamp has gone, then it's not going to work anyway.
It only shuts down the faulty circuit.
my caravan isn’t lighting up tail lights, but all other lights work fine.
However… while testing, I got a strange sequence of events.
I’ll also point out that the 13 pin socket has the left and right tail lights on different pins, so whatever it is, is affecting both sides.
The 13 pin is exactly the same wiring as the 7 pin.
Left and right tail lights are separate, one side also supplies the number plate light.
The 13 pin sockets have extra pins for reversing lights + supply etc.
I found it a little weird that replacing only some of the lights on one side then allowed the other side -where I hadn’t changed anything- to work.
If my thoughts are correct, and it’s some sort of overload protection in the vehicle relay, it must be on the shared earth that serves both circuits of side lights.
Or maybe not. Thinking.
That same earth serves ALL the road lights… and they all worked. Just the side lights were off.
littlespark
Staff member
Supporter
Patron
Scottish Borders
Strange intermittent fault on 13 pin socket
Auto Electrician Forum
littlespark,
littlespark,
