Discuss swa in conduit/pipe underground in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
O
One_of_them
As title says really?
Heard people say use in some form of piping to make life easier in future should you need to replace/pull in new cable
Others say bury direct?
What's your views
Cheers
eithewr way is acceptable with SWA. only reason to tube it is, as you say, to make it easy to replace
my problem is if water gets in it will stay in and if damaged water will destroy the steel armourings though If they are wanted or ther I would use them .
We use polyethelene irrigation pipe as ducting. It comes as 100 meter rolls and it's easy to work with and easy to pull SWA cabling through. It also helps stop the porcupines digging up the cable and destroying it.
imo, if damaged the armour will corrode whether or not immersed in water. also a lot of ducting now has very small drainage holes along its length.
Also for the reason of armour corrosion, if at all possible, i wont use armour as CPC.
Reply to swa in conduit/pipe underground in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hello, I have 50 ft of corrugated pipe buried between my house and a pool shed. I placed it where I knew future landscaping would make it very...
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
After 24 years my septic lift station pump and high water alarm needs to be replaced. It was tripping the breaker and the alarm was no longer...
Short Version Is it permissible to have 2 feeds to 2 separate consumer units in a detached garage? Is it permissible to run SWA underground...
Can anyone recommend an EV charger brand/type with load curtailment (throttling) which is easy to interface by manufacturers design, with a remote...
6K
